reading binary stream
Thanks, this help a lot.  I was starting to decode using a uint8 array.  Apparently I was on the good track.  However, my data is in little-endian encoding.  I think the typecast only support big-endian.  Any alternative?  I did found a swap byte and swap word sub-vi.
I will use this vi as a starting point to add the extra fields.
Patrick
(2,831 Views)
(2,811 Views)
