Can C code be converted into G for LabVIEW?
Hi guys,
Is it possible to convert C/C++ code into G code in LabVIEW?
(3,225 Views)
No, not with tools from NI which i am aware of.
You can compile the C/C++ code into a DLL and include that in LV using the Call Library Function Node (CLFN).
norbert
Norbert
Expert: Geometry
(3,223 Views)
Hi Norbert, thanks for the reply.
If I manage to do this, can I "emulate" microcontroller ports/memory etc using LV?
Anoop
(3,214 Views)
Accepted by topic author RedAG
Anoop,
there is a close relation between NI and ARM resulting in the Embedded Module for ARM Microcontrollers. This might already give you everything what you are looking for.
There are other, custom developed approaches like this.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,210 Views)
Thanks again Norbert.
(3,190 Views)
