Camera attributes reset to invalid values on power cycle
The issue I am having is that my GigE interfaced camera, using IMAQdx drivers, overwrites saved attributes (viewed in MAX) with invalid values on power cycling. This causes out of range errors if I don't manually open MAX and fix the values after every power cycle. For some reason changing them programmatically in a VI still gives out of range errors.
I've had issues with this across multiple versions of labview (2009 and 2017), MAX(5.4 and 17.0), and vision acquisition software (2013-02 and 17.1), on windows 7 and xp, respectively. I'm primarily trying to use the older versions because I also need to interface with a fieldpoint system.
The camera is a Blackfly 0.5 MP Mono GigE PoE (https://www.ptgrey.com/blackfly-05-mp-mono-gige-vision-poe-sony-icx693-camera#tabstrip-2) which appears compatible with both versions of the drivers I'm using. I have updated the firmware to the most recent version.
The first camera attribute that show up out of range are DeviceControl::DeviceIndicatorMode (controls whether the camera LED flashes or not). It resets to a blank value, and valid options are either "active" or "inactive". The second is DeviceControl::DeviceLinkThroughputLimit, which defaults to 1002160000. It is dependent on a number of other parameters, like acquisition speed and desired peak bandwidth. I just need to change it to a different value in max, and when I acquire an image it adjusts to the correct value (which based on the default settings is 41480000).
I have attached the data files that I'm using on the older system, found in Documets\National Instruments\NI-IMAQdx\Data
I have tried deleting the data files and regenerating them by unplugging and power cycling the camera, but run into the same issues.
Any advice would be greatly appreciated!
(3,506 Views)
Accepted by RPerkins
Isn't the most logical root cause here dealing with the camera?  The attributes are saved in volatile memory instead of non-volatile so it loses them on power cycle.
I don't know why using the VI won't set them without error.  But, I'd be curious if the camera itself has any settings that allow the settings to persist.
(3,498 Views)
Good call, I hadn't considered that some attributes would be saved in volatile memory because many of them were retained on power cycling. There were a group of "user set controls" that allow for saving different configurations to non-volatile memory, and choosing which loads by default.
Thanks for the help!
(3,478 Views)
Hi guys!
I have the same problem with a FLIR camera BFLY-PGE-23S2C-CS.
My question is... Were you able to do these checks on NIMAX? Or did you use another Software (Ex: Spinnaker® SDK)?
(2,736 Views)
