Camera Image Center lines
Hello All,
Here, I have attached the image which I want to achieve.
I need a suggestion regarding the example which I attached.
I have a beam image and I want to display the centroide of the beam and beam profile on the display. I know how to find the centroid. but I don't know how to display that value on the image.
Other thing, I have a beam image which is in greyscale, and I want to make a image like an example.
How could I convert the greyscale image into example image?
Any small help would be appreciate!
(2,864 Views)
Am I correct that you don't want to learn NI Vision routine and IMAQ processing?  That you don't want to learn the intricacies of associating Color Maps with GrayScale values?  Then I recommend you post your request here on the Forum and see if any of the Developers available for hire have the expertise you require.
(2,827 Views)
