How can I access NI Controller from NI MAX through Internet(not in the same subnet)
I really need it, can anyone help me connect from NI CDaq-9132 to my computer that installed NI MAX through the internet(not on the same subnet)
(3,191 Views)
Manually create a new device within MAX.  Then set it to be the IP address of your cDAQ.  At that point, it should find it and be enabled in your MAX.
(3,184 Views)
Thanks for your help.
But, can you explain more details, how to manually create new devices?
and how to my computer(that installed NI MAX) recognize NI controller IP address,
I mean two devices are not on the same subnet. so that IP address of NI controller just meaningful when it is used within the same subnet.
(3,159 Views)
Accepted by topic author dandynamite
1.  Go into MAX.
2.  Right click on Remote Systems
3.  Create New.
4.  Remote Device (not on local subnet)  Next.
5.  Enter the IP address of the device.  Next.
6.  It should find it then.
(3,141 Views)
can you explain how to get IP of the controller? Thanks very much
(3,137 Views)
Talk to your IT person or whoever put it on the network.
(3,120 Views)
