Calling Labview DLL from a C# app
chrisger,
I have checked the h. file
This looks like the exthample but only one declared function ( maine VI name ) present ther .
Does it mean that all vereables can be contloled by customer's aplication?
Message 11 of 13
(5,105 Views)
If you want to export more than just the main.vi the answer is "no".
Once again, check the function prototypes of your VIs in the dll's build specification. Take a look at the documentation by clicking "Help" on the build specification dialog box to learn more about building DLLs.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
Message 12 of 13
(5,094 Views)
I have followed most of the steps with ease, and understand the code & VI's, but I have a couple of questions regarding how to build the dll in this example.
1. How do I use the 'build script for dll.bld' file to generate the Sharedlib.dll in a LabVIEW project, I am using LabVIEW 2009 SP1 Professional Development System. I have made efforts to generate my own Shareddll.dll but unsure what settings you have in your build process. eg C style or Std function calls...
2. Should I then copy the dll to the C#.NET bin\debug folder for use?
Background: In my project I am trying to get C#.NET to modify the value of a LabVIEW global variable, so that Labview VI's can be controlled from the external C#.NET application. (My Lavbiew Project attached)
Message 13 of 13
(4,787 Views)
