09-30-2015 07:27 AM
Hi all!
I've made the Advanced Architecture in Labview few months ago. My question is about caalback vis.
I'm trying to open the scale edition window of MAX since a LabVIEW application. In LabVIEW, we can open this windows with a right click on a scale constant:
I think this functionnality is performed by a callback-vi.
How can I open programm the openning of this windows? Typically, the end-user will have a calibration window, for each measurement, and if necessary it will have a "Edit Scale" button to directly open this windows... Is it possible??
Thaks you per advance!
09-30-2015 07:43 AM
Sure, these functions are wrapped in the DAQ Assistant, and can be called like a normal VI. The problem is it is undocumented, and NI may choose to change some way it works, and break code that relies on it to behave a specific way. That being said here is the code I wrote which can create or edit Channels, Tasks, or Scales.
https://lavag.org/topic/18740-launching-daqmx-task-configuration-window-with-labview/#entry112620
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-30-2015 10:46 AM
Thank you, it's absolutely was I wanted!
