CSV File - Server and Labview
I save my results data from a Vision picture analysis to a CSV File. Works great! Now I want to read the CSV automatically by a server application. I need some hints or tricks to avoid access violations by the server or labview if both programs want to read / write to the file simultaneously.
What I want to do:
The server application read the output file every 30 seconds:
Read the data and delete it afterwards - so no data duplicates should accrue.
Labview writes the data to the file:
If the file does not exists: (deleted) create a new one
If the file is in use: try it next time again (to lose one or two datasets is not important)
I want to use the "write to spreadsheet" function but maybe someone can give me a tip to use this or that to do a better job! Smiley Wink
Paul
(4,343 Views)
In the File->Advanced palette, there is a nice gem called Check If File Or Folder Exists.vi.
(4,316 Views)
I am not sure you want to use Write To Spreadsheet. The functionality is probably too rigid for your application. Use the Open/Write/Close VIs and format using the Array to Spreadsheet String node.
You may want to try a minor variant to your procedure.
  1. Write the CSV file using a timestamped name. This allows multiple, simultaneous files to be on your disk.
  2. The server reads and deletes the oldest file every thirty seconds.
  3. LabVIEW creates a new file with a new timestamp as often as needed (how often is this? Don't want to write faster than you read.)
A simple <name>_YY-MM-DD-<time>.csv file name format should work for you. You can generate the timestamp string easily enough.
Let us know if you need further help.
(4,307 Views)
Hello Crossrulz,
Thank you for your help! I overlooked that VI,  works good for initialization and recreation of the file but I am still looking for a method to check if the file is occupied by another program. I found some topics about that stuff using the error code .... let’s see. An alternative could be the tool "Handle v3.51" from Microsoft but you have to use a lot of “string gymnastic”. Not my favorite topic! 😉
Paul
(4,305 Views)
Accepted by topic author Meisspa
Hi Paul,
couldn't you just try it like that (see attachment):
If error 5 occurs the file is already open.
Is that OK for you?
Best regards
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(4,274 Views)
Hi Cristoph,
thank you for your code sample. Using a case structures for checking if the file is occupied by "code 5" works greate! Thank you!
(4,216 Views)
