CRC-16 Calculation from C code
I am unable to recreate a CRC vi to calculate the checksum. The procedure mentions calculation as follows:-
The polynomial is 0x8005. The initial register value should be 0x0000. After the last bit of the
Count and packet has been transmitted, the internal CRC Register should have a value that matches that in the
block. The first Checksum byte transmitted (N-2) is the most-significant byte of the CRC value, and the last byte
of the block is the least-significant byte of the CRC.
I used the attached VI and configured as mentioned. The results are wrong:-
Some of the correct results are below:
Input: 0702000000 | CRC:1E2D
Input: 0730000000 | CRC:035D
Also available C Code:
/** \This function calculates a 16-bit CRC.
* \param[in] count number of bytes in data buffer
* \param[in] data pointer to data
* \param[out] crc pointer to calculated CRC (high byte at crc[0])
void CalculateCrc(uint8_t length, uint8_t *data, uint8_t *crc)
uint8_t counter;
uint8_t crcLow = 0, crcHigh = 0, crcCarry;
uint8_t polyLow = 0x05, polyHigh = 0x80;
uint8_t shiftRegister;
uint8_t dataBit, crcBit;
for (counter = 0; counter < length; counter++) {
for (shiftRegister = 0x80; shiftRegister > 0x00; shiftRegister >>= 1) {
dataBit = (data[counter] & shiftRegister) ? 1 : 0;
crcBit = crcHigh >> 7;
// Shift CRC to the left by 1.
crcCarry = crcLow >> 7;
crcLow <<= 1;
crcHigh <<= 1;
crcHigh |= crcCarry;
if ((dataBit ^ crcBit) != 0) {
crcLow ^= polyLow;
crcHigh ^= polyHigh;
crc[0] = crcHigh;
crc[1] = crcLow;
(13,527 Views)
Accepted by dipu2689
I'm even questioning the C code you gave us.  Based on what I am finding, that shouldn't work either based on your supplied CRC examples.  Anyways, here is a working setup.
(13,475 Views)
Thanks crossrulz.
This works perfectly!
The code is taken directly from the Atmel Crypto IC datasheet
http://www.atmel.com/Images/Atmel-8760-CryptoAuth-ATAES132-Datasheet.pdf
I lost 2 whole days trying to create a vi from the code.
Thanks again!
(13,444 Views)
Yep, that C code would not work with your example data.  It worked exactly as I would expect with the sample data in the Atmel datasheet.
So you just learned something important about CRCs: There are a TON of variations.  You cannot just say "16-bit with this polynomial".  Just in my "standard" CRC library (a VI for 8, 16, and 32 bit each), I have parameters for the polynomial, Starting CRC, Final XOR (common for inverting the final CRC), and 2 for which direction to shift the CRC and the data bits.  And then there are some that do not follow that format and have an XOR with the data and CRC before the bit shifting even starts (like the VI you initially attached).
(13,428 Views)
