C Problem in VI
first formula node of C there, giving me maxAch (61) of 1666667, and hence, distorting what i want with the rest of the VI, when i want to be 2000000? despise C/C++ etc with a passion!lol
In case VI doesnt run, i've attached pics of the probes and data etc. to show
Message 1 of 24
(4,283 Views)
Sorry, no idea what you're asking here. Are you asking if your formula is correct, or are you saying that LabVIEW is miscalculating the result, or something else?
Message 2 of 24
(4,237 Views)
as in the code within the formula node, its producing an output of 1.67x10^6 but i want 2x10^6, i suppose a C forum may be a better place to ask
Message 3 of 24
(4,176 Views)
Please set the controls to values which illustrate your problem and make those values default before saving and posting the VI.
When I set the controls to:
maxFFin = 2E+6
sCLKin = 60000000
ffin = 200000
bit = 18
taq = 3E-7
spec = 200000
The results are:
sCLKout = 60000000
maxAch = 200000
ffOut = 200000
If you do not like the formula node syntax, why use it? There does not apper to be anything in there which could not be implemented in a straightforward way with LV primitives.
Lynn
Message 4 of 24
(4,162 Views)
Your VI is driven by the controls below but the values you are using when you get your unexpected result did not get posted with your VI/message.  Please let us know.
Your C code is not particular complex or long and you're not doing anything exotic so this forum is a reasonable choice.
A little bit of context may also help here, too.  What is it your code is used for?
Message 5 of 24
(4,159 Views)
Where did you copy it from? Ask there.
Message 6 of 24
(4,148 Views)
One of the itermediate calculations in the left formula node may have roundoff problems. When I duplicated the calculation with LV primitives, I get different results when using single and double precision.
inte = sCLKout*((bit/sCLKout)+taq)
sCLKout = 6E7
bit = 17
taq = 3E-7
inte (DBL) = 35.000000000000007100
inte (SGL) = 35.000000000000000000
The ceiling operation gives different results, 36 and 35, respectively.
Reconfiguring the calculation as inte = bit + taq*sCLKout has fewer operations and may not be as sensitive to round off errors.
In the while loop the lower shift register produces a result identical to the iteration count. Just wire the "i" terminal to the output.
Lynn
Message 7 of 24
(4,129 Views)
Wow. Kudo'd that.
Message 8 of 24
(4,106 Views)
whenever i lose the line 'inte= etc' i get the output of 2x10^6 with the values of maxFFin, sCLKin, ffin , bit ,taq ,spec . probably just an instance of this working as opposed a long term solution.
changing inte to inte = bit + taq*sCLKout; stil gives me 1.67x10^6 output
Message 9 of 24
(4,076 Views)
with the inputs coming in still an output of 1.67x10^6 being produced, seen by the red arrow
Message 10 of 24
(4,064 Views)
