C Problem in VI
Looks to me like MaxAch > spec, thus sending out spec?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 24
(1,388 Views)
but spec is 2x10^6 which isnt being output?
Message 12 of 24
(1,386 Views)
Meh, remake it with LV primitives, it'll be easier to debug. 🙂
/Y
Qestit Systems
Message 13 of 24
(1,383 Views)
Zwired1
maxFFin = 2E+6
sCLKin = 60000000
ffin = 200000
bit = 18
taq = 3E-7
spec = 200000
those are the inputs, same as he screenshots of the probes i sent
Message 14 of 24
(1,356 Views)
theres the variables & controls
Message 15 of 24
(1,336 Views)
Calulating manually i get 1666666,6...
a=0
sClk=60M
inte = 36
maxACH=sCLK/inte=1666666,6
/Y
Qestit Systems
Message 16 of 24
(1,317 Views)
when i did it manually, trying to follow code, i got ridiculus answers!
Message 17 of 24
(1,315 Views)
That shows one of two things: (1) Tedious calculations shoudl always be left to computers, or (2) the code does not do what you want it to do.
We do not know what the expected results are. We do not know what the permissible ranges and combinations of input values are. We do not know what this code is supposed to do.
So.  We cannot tell whether the algorithm is correct. We cannot tell whether the algorithm accounts for roundoff correctly. We cannot tell which these versions is correct or whether they are all wrong.
Here is my VI showing how I implemented my interpretation of your formula nodes in LV primitives. As you can see there are multiple versions of some parts where I tried variations in representation and algortihm.  Note that where comparing floating point numbers I used In Range & Coerce with a tolerance of +/-1E-6 (arbitrarily chosen). See maxFFcheck as an example. I did not clean it up or document things. If you have questions, please post them.  I also added some extra outputs and indicators in the formula nodes for troubleshooting purposes.
Lynn
Message 18 of 24
(1,300 Views)
Lynn
i appreciate/acknowledge your effort, thanks. But when VI is run, an output of 1.67x10^6 is still produced, therefore producing the message at the end, "sampling rate has changed to"?
Message 19 of 24
(1,278 Views)
@dhanna wrote:
Lynn
Then your formula is wrong?
/Y
Qestit Systems
Message 20 of 24
(1,262 Views)
