Building VI for distribution
In my project I have included several VIs and built them successfully.
But when I modify one of the VIs, and then re-build the project, the following error occurs. Can anyone helP?build_error.JPG
(2,546 Views)
Accepted by splee
The error states error 8: File permission error.
It seems to me that the target file (obviously the pqtlvanlys.dll) is write protected. I see two realistic cases:
a) You have it write protected by the file settings (see windows file explorer for this)
b) You are using the target file already by some application(s).
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,542 Views)
