07-09-2012 03:51 AM
In my project I have included several VIs and built them successfully.
But when I modify one of the VIs, and then re-build the project, the following error occurs. Can anyone helP?
07-09-2012 04:02 AM
The error states error 8: File permission error.
It seems to me that the target file (obviously the pqtlvanlys.dll) is write protected. I see two realistic cases:
a) You have it write protected by the file settings (see windows file explorer for this)
b) You are using the target file already by some application(s).
hope this helps,
Norbert
