Build waveform from discrete points
Hello all
I am trying to make a custom signal generator with the possibility of an arbitrary waveform.
I have a graph with some cursors on it you can move around as you like (only in the Y direction, not the X) From these points I would like
to create a "soft" waveform, that is a waveform with lets say 500 points so the edges isn't so rough. I have attached some pictures showing what I
have and what I would like 🐵 (I have the discrete and I would like a waveform smoothness like the output)..
I tried to mess around with FIR filter, interpolation, spline functions but I don't think it is the way to go because of the low amount of datapoints I have to start
with, but maybe these functions could be a step two in the process?!
This curve is something the user is going to draw each time he starts the program, that's why I am kind of limited to around 10-20 points max to create a waveform
like the one in the picture.
Hope you understand my problem and are able to help. 🙂
Tommy
Running LabVIEW 2009 32bit SP1 on Windows 7 64Bit
(3,863 Views)
I saw the effects of the Cubic Hermite Spline Fit durring a demo and told myself "I should rember that one" for those cases where other fits give weird ringing type effects nears steps. So I never got around to using it but at least I rembered it.
I hope that helps you,
Ben
(3,854 Views)
Hello Ben
Thanks for your input, I'll give it a try.
Have a nice day
Tommy
(3,825 Views)
Accepted by tombech
here is my try... My quick input was an array of slider 😉
 If you run it in a loop the operator get's a direct feedback.
Why you don't like  splines?
Sidenote: If you choose  coerce for interpolation, you have a Pisa like impression 🙂
Greetings from Germany
Henrik
LV since v3.1
(3,810 Views)
Hello
Thanks to both for good answers!!
Henrik: I don't mind spline functions, I just though it would require more points then what I had, but I see it works great.
Nice little example you made there, thanks a lot it works great!!!!
Have a nice weekend, I know I will now 🙂
-Tommy
(3,801 Views)
