Build error
When trying to build an application I get the following error code:
Error 15 occurred at CodeSignAPI.lvlib:Get Signing Error String.vi
Possible reason(s):
Error: The Timestamp Authority URL specified does not point to a valid Timestamp Authority server, or an unknown error occurred.
Complete call chain:
     CodeSignAPI.lvlib:Sign with Certificate.vi
     AB_Application.lvclass:PostBuild.vi
     AB_Engine_Build.vi
     AB_Build_Invoke.vi
     AB_Build_Invoke.vi.ProxyCaller
Any idea what a solution might be?
Message 1 of 10
(10,892 Views)
Accepted by topic author RasmusVistisen
Hi Rasmus,
Can you provide a bit more information on the system you are using? Operating System, LV version and Project file?
I presume you are using LV2009 and including a digital signature with your stand-alone application. If this is the case, please check your "Timestamp URL" in Application Properties-->Windows Security.
Please let me know if this helps.
Thanks!
Message Edited by Morini on 10-13-2009 10:02 AM
Dennis Morini
District Sales Manager
National Instruments Denmark
http://www.ni.com/ask
Message 2 of 10
(10,864 Views)
Yes, your right, I'm using LV2009 and a project file on a Vista machine. I removed the digital signature and that solved that problem - thanks, Rasmus
Message 3 of 10
(10,860 Views)
It solved my problem too, thanks!
Message 4 of 10
(10,406 Views)
What if I want to apply a signature. Then what do I enter for the URLs so it will build without crashing?
Message 5 of 10
(10,058 Views)
This is totally correct.  I have the same problem on LV 2012, and uncheck the digital signature at the application property, the error was gone.  Thanks.
Message 6 of 10
(9,939 Views)
Are you mental. I need code signing. Our system is restrictive and will not allow us to run these applications internally without the code signing. How about you tell me why is suddenly stops working after it had been working for months?
Message 7 of 10
(8,077 Views)
I also need code signing and get the same error.
Message 8 of 10
(7,834 Views)
It turned out the timestamp server I was using changed from a free service to a paid one, which is why it stopped working. When I switched to a different timestamp service, it started working again. For the record, I am now using http://timestamp.digicert.com.
Message 9 of 10
(7,818 Views)
I solved the problem also during the day. Was the same time server issue. Anyway i wouldn't classify this thread as solved when the main solution is to just not use the tool..
Message 10 of 10
(7,811 Views)
