06-17-2021 07:51 AM
I don't have 5k to spent at the moment for Vision Software... Is there any chance to put an overlay of a Cross Hair w/t using IMAQ overlay function?
Solved! Go to Solution.
06-17-2021 07:58 AM
06-17-2021 08:04 AM
I am using an API from the camera manufacturer, which with the help of .NET api can acquire w/o the need of the Vision module. I am grabbing images from the live feed, and covert to Pixmap, then save to JPG file. I only need to put one simple cross hair (red) in the centre of the live feed.
06-17-2021 08:07 AM - edited 06-17-2021 08:08 AM
Hi grumpy,
so you are using 2DPictures in LabVIEW.
There are a lot of drawing functions for 2DPictures! You can easily draw two red lines "in the center" of the mage(s)…
(You also could fiddle with the Pixmap data directly as they contain "simple" pixel arrays…)
06-17-2021
08:17 AM
- last edited on
05-22-2026
06:02 PM
by
Content Cleaner
Hey Gerd,
Thanks for the tip! I found one other topic, where you suggested using these functions:
I will take a look and give it a try! Thanks again!
George
06-17-2021 08:48 AM
Million thanks Gerd! Since I am not familiar with these functions, and I am gonna use this app for only temporary stuff, I am too lazy to spend time figuring out how to make a cross from two lines. Instead, I just putted a circle... need only to center it more accurately, and all is done. 🙂
