Build a Json with labview
É que os tudo que é referente ao mesmo item deve estar dentro do mesmo objeto daquele equipamento, assim que funciona a uma estrutura json
Message 11 of 17
(1,323 Views)
Translated with deepl:
It's just that everything that refers to the same item must be inside the same object of that equipment, that's how a json structure works.
You wrote about 'how remove the duplicates of my JSON'. But I don't see any duplicates.
What is your expected JSON structure?
Do you want something like: EQ1 { TCP { 1{}, 2{}, 3{} } }, EQ2 { TCP { 1{}, 2{}, 3{} } }  ?
Message 12 of 17
(1,319 Views)
I'm sorry for my bad English, but that's exactly what I need
Message 13 of 17
(1,308 Views)
Could you help me with this?
Message 14 of 17
(1,280 Views)
Accepted by leandrofeder
I do not use JSONText in this way usually, but this would get you there without having to define the cluster.
Defining the cluster seems comparatively easier, if it is fixed.
Message 15 of 17
(1,267 Views)
Your JSON structure is not easily translatable in LabVIEW, because you only use objects {} where arrays [] would be much more practical.
Here is a simple solution with a slightly modified structure:
If you cannot modify your JSON structure, here is an hybrid solution:
Raphaël.
Message 16 of 17
(1,251 Views)
Thank you so much, work's perfectly
Message 17 of 17
(1,194 Views)
