Hardware supported in Labview 2014-ds2
I have an application that is tied to a very specific version of LabView (2014-DS2).
Thus, it supports the following max driver revisions
Driver LabView 2014
Max Version
PXI Platform Svcs v17.5.1
NI-DAQmx v17.6
NI-DCPower v17.6
NI-SCOPE v17.5.1
NI-DMM v17.5
NI-SWITCH v17.5
I am investigating new instruments and I need to find out whether these Instruments are supported under these older versions
Ex:
PXIe-5413
PXIe-6431
PXIe-4081
PXIe-5111
PXIe-4139
This was easy to figure out for the PXI and MXI as NI provided a table
https://www.ni.com/en-us/support/documentation/compatibility/15/ni-pxi-platform-services-hardware-su...
I have not been able to find anything similar for the other instruments.
(1,231 Views)
I have the PXIe-5413 and PXIe-4081 modules, mounted in a PXIe-1092 chassis. I can use the PXIe-4081 module without any problem. I use Labview 2014.
I want to ask you if you were able to use the PXIe-5413 module with the LabVIEW Real Time 2014 version. What version of the FGEN driver did you use?
best regards
Frederick
(495 Views)
If you check the link mentioned in the original post you can select your PXIe-5413 and see that you will need at least FGEN 17.1 for Windows 10 and FGEN 2023Q1 for Windows 11. And then you can go to the FGEN download page listed in that table and select 17.1 and read the View Readme link to find the relevant Release Notes and see there that it does support LabVIEW 2014. That Release notes document also the supported hardware products.
Rolf Kalbermatter  My Blog
(472 Views)
