[Bug ?] LV2015 SP1 : scrollbar of string constant
Setup :
  • LV 15.0.1f1 (32-bit)
  • W7 64-bit
  • Automatic Tool Selection = ON
I have just noticed that, when trying to move the scrollbar of a string constant to change the visible text, the constant is moved on the diagram. With the scrollbar of a string control, the behavior is expected.
Am I missing something obvious ? Is this a known bug ?
(5,283 Views)
It looks like a bug to me.  I'll add one more thing to it.  The scrollbar buttons do work, but very poorly.  It takes multiple clicks on the scrollbar button to get them to go up or down a line.
(EDIT:  And if automatic tool selection is off, then even the scrollbar buttons do not work.)
(5,274 Views)
To NI :
Do you consider this like a bug ? If so, is there already a CAR number ?
(5,210 Views)
This bug has been reported as CAR 598986.
(5,091 Views)
CAR 598986 was fixed in LabVIEW 2017. See the 2017 LabVIEW Bug Fix List for details: https://www.ni.com/en/support/documentation/bugs/17/labview-2017-bug-fixes.html
(4,779 Views)
