Boolean Build Array
I am struggling to work out why the value of the single boolean shown below is not concatinated to the appended arrary from the build array?
I understand that it is not an arrary but a value from a shift register. But surely I can use that value T/F and have it added to the build array some how.  please advise I think I am going mad :manembarrassed:BuildBooleanArray.png
(4,444 Views)
You're not showing enough elements in the array.
You go from a U32 to a boolean array, so you would have 32 elements in that array.
Then you build the scalar boolean onto the end, so now you have a 33-element array.
But your indicator is only set to show 5 elements.
One thing I find odd is that you have a coercion dot going to the Appended Array indicator terminal.
(4,436 Views)
ok thanks.
I have changed a few things now the coercion dot has gone.  My new pic also shows the fully extended indicators.
Because it adapts to source -  the indicator now shows a boolean array of 9 not 5 which is what i need.
(4,423 Views)
Accepted by hawkstringer
You still have a coercion dot on Indicator0001.  Since you are now converting a U8 to a boolean array, but indicator 0001 only shows 4 element.  Is it safe for me to assume that your indicator is somehow defined as a fixed-size array?
I would avoid using a fixed array datatype.  If you only want the 4 elements out of the original 8 element array, then use Array Subset to get only the elements that you want.  Then all of your later calculations will work and display properly.
(4,412 Views)
sorted - thanks I used  subset after the conversion - bobs was your uncle etc...:0)
(4,407 Views)
