Blinking Indicator without Event Structure
Hey everyone, this question should be worded a bit better than my past ones. I finally completed Core 1 and 2 so now I actually have a grasp on what I'm asking. Haha!
Anyway, I have a custom set of sensors that interface through a com port and output a weight that is summed.  The weight is then put through a case structure to give different "bucket" sizes.  The different cases output values to a slider that the user sees. It's just to give an idea as to how big the load is.
What I need to do is make a boolean indicator that will blink if it sees a significant change in the weight. The weight is anywhere between 0 and 20lbs so I figured that a change of 1lb or more would be a great time to activate the blinking.  I also need it to only blink for a short amount of time (10 seconds max).
I've tried to use event structures based on the slider and a property node. I created an event based on a value change and put a blinking property node in, but all that did was cause my front panel to lock up.
Any ideas?
_____________________________
(6,223 Views)
Right click your boolean indicator on your block diagram and create>>property node>>blinking. Right click the newly created property node and change it to a write. Now just feed it a True when you want it to blink and a false when you don't as long as it is in a loop.
Now Using LabVIEW 2019SP1 and TestStand 2019
(6,217 Views)
I've gotten that much, but where I'm having problems is how to feed it the true and false value.
The true would be if the change in weight is greater than 1 and the false would be if the change in weight is less than one.
Is there a way to slice in some kind of boolean/numeric/comparison that basically says "if change in value > 1 then true"?
(6,215 Views)
Accepted by topic author Matub
Well without seeing your vi one way to do it is to feed your weight measurement into a shift register on the right hand side of your loop. Grab the shift register on the left hand side and drag it down. This will give you the previous iteration of the shift register value that you can compare to the present.
(6,213 Views)
A SHIFT REGISTER! ARGH! I can't believe I didn't think of something that simple...
Just a heads up, it worked beautifully.
Accepted solution and Kudos to you, sir!
(6,208 Views)
