Binary to integer array trouble
So I am trying to read a .dat file and output an array of 4byte (32-bit) integers.
My current attempt is to use the Read from binary file. From here I use a StringSubset.vi to remove the first 834 bits as this is non-important information. From here I want to assemble the following string of binary into 4-byte integer values. I am unclear with what sub vi to use after removing the non-important information to convert packets of 4 bytes to numbers.
Any help would be super appreciated.
Message 1 of 11
(5,737 Views)
If you have an array of U8, you can type cast into an array of U32. This will naturally use 4 elements of the input array to create 1 element in the output array, with the most significant byte being the one with the lowest array index.
Message 2 of 11
(5,719 Views)
*.dat is a generic extension and does not tell us anything about the data structure.
Do you have a typical datafile with known data? Please attach it.
After trimming 834 bytes, you might try to "unflatten from string" with a 1D I32 or U32 array as type.
Do you know the byte order? Try big endian and little endian to see which produces a more reasonable output.
Message 3 of 11
(5,713 Views)
This would swap the byte order.
Message 4 of 11
(5,657 Views)
Accepted by Jewsus
The original VI generates a string, so unflatten as suggested seems like a better choice. Easy to change byte order for testing. 😄
Message 5 of 11
(5,649 Views)
Message 6 of 11
(5,643 Views)
It might be easier to split the read in several operations. Either first read a chunk of 834 bytes and process it as header or throw it away or just set the File Offset to 834 bytes from the start. Then read the remaining data with Binary Read and the correct data type.
Rolf Kalbermatter  My Blog
Message 7 of 11
(5,634 Views)
Accepted by Jewsus
My initial thoughts match what rolfk stated.  Just have the Read Binary File do all of the conversion for you.  Just wire an I32 constant to the data type input (on the top of the Read Binary File).  You can also supply the byte order just in case the file is using little endian (big endian is the default).
Message 8 of 11
(5,596 Views)
Thanks so much alten, that worked out nicely. I can't believe how much trouble I was having with something so simple lol. Have a great day
Message 9 of 11
(5,578 Views)
Who is alten (altenbach I presume)?  You selected crossrulz' solution.
Message 10 of 11
(5,568 Views)
