Best way to find the center of a circle
Hello!
I have a project where I have to identify a green circle and the center of it. So far I have filtered out the green particles (using color threshold and erosion &dilation) so I have a binary image of a more-or-less circle. I have been looking at solutions to identify my object and get the center coordinates. Can you help me explain a little which method would be the easiest/best and why
1. IMAq Find Edge.vi : where I adjust the line fit to Hough Edge Rake
2. at Help->Find Solutions under the Vision option I found a Particle Analysis Report.VI
3. Machine Vision> Searching & Matching > IMAQ Detect Shapes
Thank you in advance!
(3,651 Views)
Which have you tried?  Have they worked?  Note that you can "test" the algorithms by creating an image with a known Circle and verify that your "find the center" routine finds the "right answer" (what good is an algorithm if it gives the wrong answer?).
(3,631 Views)
You can convert all your circle points to xy coordinates then use "fitting on a sphere" with a matching z array that is all zeroes. (For z=0, it will fit a circle). It will give you the radius and center.
The algorithm is plain linear algebra and has been discussed several times.
(3,627 Views)
Posting an image of that might be useful...
(3,573 Views)
