Best method
Hi Veeru,
here is a simple example, how you can do it with a vi template.
Hope it helps.
Mike
Message 21 of 27
(1,615 Views)
@Pnt wrote:
That is another option to run two subvis in parrallel
Are you sure of this option? I suppose the event-handler won't be able to process next event until the subVI it launches hasn't ended execution.  Maybe you have to launch VI inside event structure, not actually put the subVI, am I right? Sincerely, I don't know so deeply events, I seldom use them...
graziano
Message Edited by Graziano on 07-17-2008 08:07 AM
Message 22 of 27
(1,610 Views)
Hi Pnt,
i´m also not happy with your solution. Veeru speak about 18 vi´s and maybe it become more. Furthermore i think one event structure per vi should be enough. Smiley Happy
Mike
Message 23 of 27
(1,604 Views)
Hello Veeru,
I am in the middle of doing something very similar to you.  I have a bunch of buttons on a front panel and each button must launch a seperate VI (in parallel).  I store the filename of the corresponding VI in the button labels.  When a button is pressed, first I check to see if the VI is already running.  If it is, I ignore the button, if not, I execute the VI using a run VI invoke node and then open the front panel.  I have each individual subVI close it's own front panel before it stops executing.  To get the output of the each VI I think you can use an invoke node with "Control Value Get".  VI is attached.  Hope that helps! (I am new to labview too).
Jorge
Message 24 of 27
(1,602 Views)
Where i write subvi 1, you put there the sub vi itself.
There is no dependency between two loops so the main vi can launch another vi, before previous has ended.
Mike write:
I don't like it either because of the 18 vis Smiley Very Happy
But it is the simpler and more safe! Good to know it, even if you don't use it.
Message 25 of 27
(1,587 Views)
Okay, I thought that you put 2 screenshots of the same event structure: my mistake, it was easily seen that then sequence number is the same, so it was impossible, sorry! Smiley Happy
graziano
Message 26 of 27
(1,580 Views)
Thanks everyone for your help
The discussion is interesting,when i look at Mikes ex(mesage 21) its interesting.
i will proceed with the tips from this issue.Also thanks Jorgewpi. If there is any problem involved pls let me know.
Message 27 of 27
(1,570 Views)
