Best method
Hi Veeru,
why are you confused? Your method is ok, i only meant if all of the 18 vi´s make near the same, you can use a vi template. Then you can connect the vit path to the "Open VI Reference" vi and call it in a loop 18 times. You will automatically get 18 instance of your template.
Mike
Message 11 of 27
(1,541 Views)
Thanks Mike
Is the right method i am using.
Message 12 of 27
(1,537 Views)
Mike
Do u suggest, Open Vi Reference method
Message 13 of 27
(1,534 Views)
Hi Veeru,
yes. I think, it´s the best way to run multiple vi´s parallel.
Mike
Message Edited by MikeS81 on 07-17-2008 01:13 PM
Message 14 of 27
(1,532 Views)
Thanks a lot Mike
Message 15 of 27
(1,527 Views)
That is another option to run two subvis in parrallel
Message 16 of 27
(1,504 Views)
The vis runs in parallel(i mean all the 18 applications are activated from the main VI).If i am not clear pls let me know
Veeru does any of the 18 subvis need a trigger or needs to wait for trigger or stop on triggering.That might create a problem. just throwing up a caution.
Message 17 of 27
(1,499 Views)
You close the ref. just right after you open it. It is wrong.
You should do it when the vi has finished execution.
Message 18 of 27
(1,493 Views)
oh, that´s right, sorry for didn´t see it.
Mike
Message 19 of 27
(1,483 Views)
Thanks Muks and pnt
Yes,all the 18 application is triggered manually(press a button to open a new FP).What are the possible problems
Message 20 of 27
(1,482 Views)
