transform two 2d array into one positional 2d array
Hi, hopefully this is very easy:
i have two 2D arrays say:
1 2 3                                3 5 9
5 6 7           and               7 3 1
what i want to do is pair up the numbers in like positions and generate a 2D array as such:
1 3
2 5
3 9
5 7
6 3
7 1
so the positions within each of the parent matricies are like for each line.of the new line.
Help!
(3,056 Views)
Hi John,
you can first use the reshape array function to create two 1D array´s of your 2D array. After that use the build array function to get your new 2D Array.
Mike
(3,054 Views)
Simple. Direct. Mike.
And there you have it. 🙂
____
Ryan R.
R&D
(3,039 Views)
