Beginner question: how do I get my program to write to another file after so many loops?
Im trying to get my program to write to a different file after 65,535 loops. Firstly can I create a file to start with, so operator will not be needed for the switch over? Secondly how do I get it to change from one file path to another, some kind do while satement? I have attached my program, I am also not entirely sure what the two current file paths are used for, is it one to call the file and one to save?
Cheers
Message 1 of 8
(3,980 Views)
Use a loop count (i in while loop) check for your condition and use a write to spread sheet function.
Message 2 of 8
(3,976 Views)
Accepted by ssteel
Attached VI will give you some hints.
Christian
Message 3 of 8
(3,972 Views)
sorry, my task has been changed, now every 12 hours I have to save data to a file named as the date followed by either 00 or 12 depending on whether the time is between 00-11.59 or 12-23.59. Is this possible. Can someone tell me exactly what the two file paths do which are attached to my write to spread sheet function? If Iwant to do this, do I have to create a load of files already which are named, or can I set this up in the program so that no one has to supervise the change over between files?
Sam
Message 4 of 8
(3,943 Views)
Again, the attached VI from the post before should give you some hints!
You just need to work with the Get/Date/Time String.vi or Get/Date/Time in Seconds.vi to determin when you want to create your new file,
how to create the new file will be shown in the attached VI from before.
Christian
Message 5 of 8
(3,935 Views)
But how do u input a file path which is then going to be an input for the write file vi? I need someway to get the date given from the date/time string vi into the name of the file??This is what Im struggling with. Im not sure why there is a file path in and out of the write file aswell??
Message 6 of 8
(3,917 Views)
Please post an image of your current code so we can follow along. So this is a 24 X 7 anemometer app? Just curious,
Ben
Message 7 of 8
(3,914 Views)
it will be hopefully, the aim is to get outputs from 3 accelerometers and 2 anemometers feeding into a spreadsheet. But I'm just starting with the one anemometer. The program so far is attached. My aim is to have a case structure which will create a file called 'the date'_00 and a case structure which will create a file called 'the date'_12 depending on the the output of the time (at the bottom of the block chart). Making 2 files a day. But how do I get these file names in the file path. It is true that if the file name given in the path doesn't exist then the file is created?
Message 8 of 8
(3,907 Views)
