Back and Forward Buttons
Dennis,
I found my problem.  I had the Truck Number VI in a While Loop.  I removed the while loop, which helped.  Now I can navigate properly.  Next I went into the Truck Number VI and put a sequence around the diagram.  I added a frame after and put a reinit all to default in the second frame.  It seems to work properly now.  I'm gonna see if I can redo my other VIs with event structures.  Let me know if you have any advice.
Thanks so much!
This Bud's for you!
Drew
Message 11 of 13
(599 Views)
How did you change the data type in the event structure.  Yours is green and says NewVal.  Mine is blue and says Time.  I need to make mine look like yours.
Message 12 of 13
(595 Views)
Right click on it to select a different item or add an element. You can also drag on it to add/remove items.
Message 13 of 13
(579 Views)
