Array
Hello!!
As you it can build a womb of two columns in that the first column the values are x, and in the second column the values are y?
To this womb I have to incorporate him those the values that there is in a. txt
(3,792 Views)
(3,787 Views)
The solution should be as simple as
However, you may have a problem with the decimal separator. Check first if your PC is configured with a dot or a comma as separator (english/french). You can replace all the comma with dots, as shown here
By the way, the correct translation for "matrice" is "array"... et non"ventre" ! 😉
Message Edité par chilly charly le 08-18-2005 02:32 PM
Chilly Charly    (aka CC)
(3,779 Views)
Thanks a lot!!!!!!!!!!
Greta
Smiley Wink
(3,758 Views)
