mulitples notificators
hi , i would like to have the function of multiples notificators from the same library as in file attached
TheGame
(2,700 Views)
I have no idea what that means.
Do you know how to use notifiers?
Did you try looking for examples and tutorials and reading the help files?
If you have, and you understand what notifiers do and how to use them, explain what you want to do and why.
If you haven't, you should learn about notifiers first.
___________________
Try to take over the world!
(2,692 Views)
When you use the Obtain Notifier (may be called Create Notifier in earlier versions of LV) function, give each notifier a different name. That will create a different refnum for each one. Use the refnums to distinguish between them.
Notifiers can be a bit tricky to learn. I suggest that you make some simple examples and run some tests to make certain that you understand how they work and that they are doing what you want. The Help files are very useful for this also.
Lynn
(2,690 Views)
