BUG: Nested cluster Value change events
@mcduff wrote:
Here is one more, somewhat crazy, example that may/may not convince you, this is not a bug and expected behavior.
One the front panel I have a Tree Control. The only way to interact with the control is with the mouse. I am registered for the following events: Mouse Down and Value Change. If I change the value on the front panel with the mouse the following events occur: mouse down, then value change. That is always the order of events.
Now in my block diagram I set the Value(Signaling) property node. What events should trigger? Should it be only a Value Change Event (no bug) or a Value Change and Mouse Down Event (bug)?
Why on earth would you expect a Value (Signaling) to trigger a mouse down event?
This has nothing to do with nested controls nor cyclic event nor events triggering events.
Value (signaling) triggers a Value change event, it's not a simulation of a user clicking to change the value. That is the reason a VS triggers a VC and not a Mouse Down event.
Again, no event triggers another event. The user clicks, that triggers a mouse down event. The click triggers a value change, that triggers a value change event.
Message 21 of 37
(1,062 Views)
On the Front Panel, a value change on the Tree cannot occur without a Mouse Down Event. You are expecting the the Value(Signaling) to act just like Front Panel Event, so why not? (I do not expect this behavior that is why I do not think this is a bug.) You are expecting the Value(Signaling) Event in Main Cluster to trigger any events subelements in that cluster may be registered for.
Why do you expect events for actions that preceded the Value(Signaling) Event?
Message 22 of 37
(1,057 Views)
Here's a strong indication that events are not generated by events (but instead by the Value (Signaling).
The TO is the only event in the event structure: what you see is all there is.
Boolean 1 is a control in each and every way exactly the same as Cluster 2 is a control...
So why does the Value (Signaling) put a Cluster and a Boolean 1 VC event on the event queue, but not a VC event for the Cluster 2?
Spoiler
Because it's a bug...
Well, at least it's not expected, and even if you would expect it, it's debatable to a degree that there should be documentation added to the help.
Message 23 of 37
(1,054 Views)
Look at the example provided in the beginning of the post. I change the subelement of a cluster then another event occurs, value change of the main element. It is actually the same event, but two event cases are executed.
Message 24 of 37
(1,053 Views)
UI interaction (including mouse down - with associated filter event if required) and setting a value change programmatically are not the same thing.
I would not expect a value changed event fired from the BD to trigger a mouse event, that would be plain wrong. I don't see what this has to do with the OPs report of cluster vs cluster elements.
Message 25 of 37
(1,050 Views)
Spoiler
Look at the event log in Message 5, two events occur when the subelement is changed.
Maybe you should have NI chime in, I still do not think this is a bug and if worked the way you want it to work then there would be issues.
Message 26 of 37
(1,050 Views)
I absolutely DO NOT expect a VS to act like a Front Panel Event.
I don't.
I expect value change events when the value changes (or it can actually stay the same if VS is used).
A value signaling should trigger a value change event.
All your logic doesn't explain why this works for an element in a cluster (expected), but not for a cluster in a cluster (expected).
Message 27 of 37
(1,048 Views)
It's not the same event.
2 events are enqueued, because two events where registered.
I flush the events. If it was 1 event, the other would be empty.
Message 28 of 37
(1,045 Views)
I don't.
Just to add my POV: I agree that it's super inconsistent behaviour that warrants the label bug, whether documenting WHY it is like this (good luck with that) or fixing the fact that it shouldn't be like this, either way, I see no way past labelling this a bug.
Message 29 of 37
(1,042 Views)
While your VI is running, you can press the Tab key on your keyboard to set key focus on a tree control. You can then use the arrow keys on your keyboard to change the selected row (i.e. the value) of the tree control. No mouse interaction required.
Message 30 of 37
(1,004 Views)
