04-11-2026 01:15 AM
Hello, I'm currently working on code to allow a robotic arm to move its 3 different motors automatically once it reads the input a user types. I currently have it so that it can move manually, but not automatically, through 3 different DQ assistants attached to build arrays and switches, in a while loop. It also reads the arm's current position through a DQ Assistant and displays three different outputs: height, in/out, and rotation, also in a different while loop. Can I get some pointers or example code on how to write part 2 of the code that will read 3 different inputs and move the arm accordingly? Having trouble finding resources.
04-11-2026 07:02 AM
Robotic programming is always a bit tricky. But my first recommendation would be to actually learn DAQmx programming and forget about those DAQ Assistant Nodes. They are great to begin doing a single task without knowing anything about programming but they quickly detoriate into an uncontrollable mess once you need to do more than one thing simultanously.
04-11-2026 10:44 AM - edited 04-11-2026 11:05 AM
This seems like an architectural nightmare, but we can't really tell from your description what you are actually doing.
For motor control, one would typically use NI-motion. I have never head of "DQ assistants". Can you explain your hardware?
You cannot "built arrays and switches in a while loop". Can you show us your code drafts so we can get a clearer picture?
Can you explain the three user inputs? Why do they need to be different? Do they just define e.g. an xyz position? If this is a robotic arm, you might need to solve inverse kinematics. Have you worked out all the math based on the arm geometry?
