Authenticate api
I was given an API to extract info from it. But before I could use, I need to authenticate it. Can anybody show me how to do it? The expected response would be a token in json format. Thx.
(1,115 Views)
Too vague,
  1. Is it a REST API?
  2. Do you use native LV REST API or other libraries?
  3. Your API documentation will define how to authenticate (typically it will be through headers)
Please share your API documentation
Santhosh
Soliton Technologies
(1,101 Views)
yes, it is Rest API. Pardon me as I am still new to labview. As I was only given an URL to work ( with the API residing in the server), hence there is no API document specifically.
(1,097 Views)
There needs to be some documentation. There are virtually umpteen ways to do authentication. The authentication not only can be passed as URL parameter or inside the HTML header or the body in any of JSON, XML, or whatever format, but the algo used to calculate the authentication, the actual encryption routines, ciphers and envelop and padding formats all need to match exactly too.
Rolf Kalbermatter  My Blog
(1,056 Views)
