Arrays to control
I want to read numbers from an array one by one to use them as a control to an input.
How can I extract a number one by one from an array to use its value as a control?
This is my actual code (image attached).
I want to replace the control value in the red circle with a value taken from an array, and make a cycle for it to read all the values in the array... changing wether by a timer or a click...
(2,902 Views)
When the array is outside of a For Loop, and all that other code is inside a For Loop, use an auto-indexing tunnel when you feed the array wire into the loop.
I would recommend looking at the online LabVIEW tutorials [links removed; articles no longer available]
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
(2,873 Views)
You haven't looked at the In Range and Coerce? Function on the comparison palette have you?
What array?
That is not your code!  That is a picture of code.  Attach code please or, a snippet (those are pictures that contain code embedded in them.  See menu edit>> create snippet from selection)
"Should be" isn't "Is" -Jay
(2,864 Views)
