Array of queues
I've been able to control 6 seperate NI modules by having all 6 have their own queue and I put that into an array.
  • I can obtain 6 queues in a For loop and output into an array
  • I can access each queue using index array and which position I need
  • I can create a VI which iterates through each queue in a for loop and if I only want to control say position 1 and 3 then ignore 2,4,5,6 i use the timed out? boolean
The issue i'm seeing is if I use index array to stop position 1 and say flush queue, it looks like it flushes the entire array of queues. Am i overlooking something?
Message 1 of 14
(4,103 Views)
You could be overlooking something.  But we don't know because we can't look over your VI.  When you don't attach code, we can't see what you overlooked.  It is impossible to debug paragraphs.
Message 2 of 14
(4,089 Views)
attached is a snippet from my stop position code. It requests which position to stop and uses that enum control to set the index position for array. It flushes the test array queue for that individual position if its in the middle of a test.
Message 3 of 14
(4,072 Views)
And where is the code where you initialize the queues?  It is possible you are reusing the same reference and/or named queue.
Message 4 of 14
(4,064 Views)
I have used arrays of queues previously and had not trouble with them.
That image does not help since the problem is most likely elsewhere.
I suspect you are not keeping the queue refs in a shift register and when you stop to For loop you are loosing your refs.
Ben
Message 5 of 14
(4,063 Views)
That's not code.  That is a picture of code.  It doesn't show everything we need to see.
Message 6 of 14
(4,047 Views)
True.
From what little we see there is a possibility that is a FGV being used there which is as prone to a race condition as any global variable.
Ben
Message 7 of 14
(4,043 Views)
Assuming your project is developed using the LabVIEW Project file (.lvproj), compress the folder holding the Project (and most of the VIs, TypeDefs, etc. that you use) and attach the resulting ZIP file.  We need to see as many pieces of this puzzle as we can to find the bug ...
Message 8 of 14
(4,038 Views)
If you create named queues and have the same name, you'll in fact have 6 copies of the same queue, and then a Flush will empty it/them.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 14
(4,033 Views)
/Y
Nice post!
I now understand what Tim was hinting at in post #4.
Spoiler
Yes, some days I can be dense.
Ben
Message 10 of 14
(4,024 Views)
