Array of clusters
I would like to obtain an array of clusters of two elements (x,y). The user should be able to choose ending values (ev) of the elements, and the starting value (sv) is always equal to one E.g.:
1. (sv=1, ev=2) gives in the result: (1,1) (1,2) (2,1) (2,2)
2. (sv=1, ev=3)
(1,1) (1,2) (1,3) (2,1) (2,2) (2,3) (3,1) (3,2) (3,3)
3. (sv=1, ev=4)
(1,1) (1,2) (1,3) (1,4) (2,1) (2,2) (2,3) (2,4) (3,1) (3,2) (3,3) (3,4) (4,1) (4,2) (4,3) (4,4)
3. (sv=1, ev=4)
4. and so on…
I am working with LabVIEW 8.6. Any help appreciated.
Thanks!
Message 1 of 8
(4,522 Views)
What you ae asking for is trivial using a pair of nested For loops a shift register and a build array node.
Investigate those functions and post images of your code if you get stuck.
Ben
Message 2 of 8
(4,517 Views)
Yes, I believe that this is trivial but I am fairly new to LabVIEW. Where should I put the shift register?
Message 3 of 8
(4,507 Views)
on the outer For loop. It will acumulate your work as you go.
Post images if you want better help.
Ben
Message 4 of 8
(4,496 Views)
I have something like this and it works, but think there might be a better solution.
Message 5 of 8
(4,483 Views)
What a difference an image makes!
That is better than what I had in mind if you are OK with the 2D array. If you want it to be 1D you can reshape (see array palette) the results to 1-d.
Ben
Message 6 of 8
(4,477 Views)
Thanks Ben!
Message 7 of 8
(4,469 Views)
Just change the constant 4 to a Control wired to both N's and you've solved the user input question. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(4,446 Views)
