Array of Relative Time and Data
Hello dear Labviewer
I have a Daq device which measures pressure as data in the Y-axis, and i use the relative time in the X-axis of the Waveform Chart. Now i want to make a array with 2 columns (Time and Data). I use that build array function with both my relative time and data, but how do i connect the relative time from the chart to the build array function ?.
Best regards
Oesen
Message 1 of 16
(4,468 Views)
I could not get relative time of chart.
But you may use tick count or elapsled time vi to generate your own relative time data.
Labview user
Message 2 of 16
(4,457 Views)
hi
check the attached picture vi.
Freelance_LV
TestAutomation Consultant
Message 3 of 16
(4,449 Views)
Hi Aojha.
Im afraid of there will maybe occur an offset time between the Chart time and the elapsed time, if i use that procedure ?
Best regards
Oesen
Message 4 of 16
(4,432 Views)
Hi Freelance_LV
What's the relationship between this Vi and my Vi ?.
Best regards
Oesen
Message 5 of 16
(4,429 Views)
You can use the Get Waveform Time array and subtract the t0 from each element.
Message 6 of 16
(4,426 Views)
Hi Dennis.
Is this okay?
Best regards
Oesen
Message 7 of 16
(4,413 Views)
It's okay only if you only want to write the time information and not Y data. In your first image, you had a build array to have the two columns. Why did you get rid of that?
Quite frankly, I don't understand what all of that code is doing. The wiring is a mess.
Message 8 of 16
(4,398 Views)
The first part is to get rid of those crazy time numbers since 1. January 1904. Now i start my start time of the chart is 0 instead of something like 234324234.
The second part is to get rid of the random offset because i want to define the first data value as zero
Best regards
Oesen
Message 9 of 16
(4,393 Views)
I have tried this solution, but i only get th Y-data and not the X-data (time data). Is there anything wrong ?
Thanks in advance
Oesen
Best regards
Oesen
Message 10 of 16
(4,364 Views)
