Use Unicode character set in Labview
Hi I'm an italian boy an I would read from a Unicode file a string. I
tried using the "Read Line From File" but it didn't work. Only with the
"Read File" I can read the file but I don't know how display the
Unicode characters. In particular I would display russian characters in
a string indicator. How can I proceed?
Thanks in advance
ale
P.S.: sorry for my poor english...
(8,602 Views)
Thanks in advance
ale
You have several problems here. First Read Line from File is specific to read ASCII files. It won't work on binary files which Unicode files are for LabVIEW.
Displaying is another issue. LabVIEW is inherently ASCII with some Multibyte character support for foreign language installations. Multibyte is something entirely different than Unicode although it has the same inentions but in very different ways.
So you won't be able to display Unicode text in LabVIEW directly. You can call the WideCharToMultiByte Windows API function to convert your Widechar Unicode array into a Multibyte string and provided you have set the right font for the specific control you "might" be able to see your Russion text.
I've posted a VI library that interfaces to the WideChar Windows API functions already in http://forums.ni.com/ni/board/message?board.id=170&message.id=123821&requireLogin=False so you can directly try with that.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(8,594 Views)
From NI Germany staff I got the information that there is an undocumented ini setting for LV. You must have Windows with Unicode support and Unicode fonts (e. g. XP).Then you must insert the line "UseUnicode=TRUE" in the LabVIEW.ini file. This way your characters should be diplayed correctly in controls and inidcators. I don't know if you can read and write Unicode files correctly this way. This information was for LV 7.1.1 but I think it should also work with LV 8.0.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(8,583 Views)
    I need the complete character set file for English for my project. Is it possible for me to get from national Instruments?
(6,908 Views)
The Unicode support that is available in LabVIEW in this way is not a feature of LabVIEW but of the underlaying OS. So you should ask Microsoft for that.
(6,901 Views)
  Where can i find a demo on how to bulid an OCR using labview?
(6,878 Views)
This is totally unrelated to the original topic of this thread. Start a new thread!
(6,874 Views)
