Array inside cluster doesn't have a name?
Hey, hopefully this is a quick one (I tried googling but couldn't get an answer).
In my code I'm using a cluster of various data types, one of which is an array. The issue I'm having is I can't use unbundle by name to access the array- because it has no name.
The array starts off by being initialised using the initialise array subVI. I've attached a screenshot (ignore the rest of the code).
Is there a way for me to assign a name to this array so that I can unbundle it by name? It would make certain parts of my code a bit neater as at the moment I have to use a regular unbundle.
Thanks!
(3,703 Views)
Hi nishalc,
right-click the middle terminal of the bundle node -> create constant. In this cluster constant you set the label of the array…
(You should create a typedef for your cluster and use (Un)BundleByName anyway!)
(3,697 Views)
Accepted by topic author cna
Do it like this.
=== Engineer Ambiguously ===
(3,692 Views)
EDIT: Just saw the other reply which explains it, never mind
What would be the advantage of making my cluster a typedef?
(3,684 Views)
Hi nishalc,
when you change the typedef all instances of this typedef will automatically adapt…
(This becomes even more handy when you use subVIs to handle your cluster!)
(3,659 Views)
I wrote a Nugget to answer that question that can be found here.
Ben
(3,643 Views)
