12-01-2016 09:26 AM
Hey, hopefully this is a quick one (I tried googling but couldn't get an answer).
In my code I'm using a cluster of various data types, one of which is an array. The issue I'm having is I can't use unbundle by name to access the array- because it has no name.
The array starts off by being initialised using the initialise array subVI. I've attached a screenshot (ignore the rest of the code).
Is there a way for me to assign a name to this array so that I can unbundle it by name? It would make certain parts of my code a bit neater as at the moment I have to use a regular unbundle.
Thanks!
12-01-2016 09:31 AM - edited 12-01-2016 09:32 AM
12-01-2016 09:33 AM - edited 12-01-2016 09:34 AM
Do it like this.
12-01-2016 09:36 AM - edited 12-01-2016 09:37 AM
EDIT: Just saw the other reply which explains it, never mind
What would be the advantage of making my cluster a typedef?
12-01-2016 09:53 AM
12-01-2016 10:44 AM
I wrote a Nugget to answer that question that can be found here.
Ben
