Showing results forĀ
Search instead forĀ
Did you mean:Ā
Array init problem
Hi !
I have a result array (FailArray2 , look attachment LV70), what is not
working propely. If i run this code several times, result comes end of array and
arry size is growing every run time.
If i connect "Init Array" before For loop , every results comes first row.
How this must be done that every run time i get right 2Dimension array ?
IF i make EXE this LV how it's works then (this is Sub VI)
-HeVi-
(3,077 Views)
i think you have to use one more shift register in the outer for-loop.
I hope the modified example does what you want.
When you build a Application (*.exe) there“s no change in the handling of the Code.
Regards and i hope this helps,
Alex R
NI Switzerland
(3,066 Views)
Yes, it's work now, Thanks !
Simply thing but sometime ...engine jam...or.......
-HeVi-
(3,062 Views)
