save xy-graph
I want save the xy-graph results in that way it includes also x and y axis...I mean that the results include both axis and the line/curve what are measured...If I use Labwiew write measurement file vi. it saves the result to lvm form...Should it saves like a picture etc. ??
(2,922 Views)
Hello jiv,
you are right, .lvm is a file that only includes the measurement data. If I undestand you right, you are looking for a way to save a picture of your graph.
you can do this with the report vis. Allthough they were designed to create a printable report you can also create HTML files and attach images of your controls to them.
For problems concerning the usage of the report VIs together with the DAQmxBase driver, refer to your other threads in the forum.
There is another solution as well, making use of VI or control methods. you can create an image of your frontpanel or any control and savi it as a file. The attatched vi shows you how it works. It creates a screenshot of the complete frontpanel and saves it as a jpg file.
Message Edited by IngoS on 05-04-2005 01:56 PM
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(2,907 Views)
