Array data type conversion
I have a simple problem.
I have a 2D array of string type. The array is a table with column names, and rows which are numbers.
I want to extract the rows, but I want them to come out as numbers so I can do some line fitting to them.
Do I need to select each element and convert from string to number?
Is there a function that converts a string (pink line) to a number (orange line)?
Is there a smarter way?
(9,145 Views)
Try this...
on the blockdiagram right click go to programming-->strings-->string/numberconversion-->fract/exp stringtonumber
Robin
(9,142 Views)
Thanks. Your solution works but element-wise.
But is there a VI that applies to the whole 2D array to change its type?
(9,134 Views)
Spreadsheet String to Array in the String palette.
Lynn
(9,124 Views)
Put the 2D array through a For loop.  See attached.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
(9,122 Views)
Accepted by topic author murchak
It works on an entire array at a time in my version of LabVIEW!
(9,114 Views)
It does indeed work on an entire array. Thanks!!
(9,081 Views)
