Arduino Servo + Button
Hey People!
Programm in Picture 1 does work: if i press the button the DI Value Indicator blinks.
Programm in picture 2 does work: if i set a number higher than 2, the servo moves, if i change to a number lower than 2, the servo moves again.
Programm in picutre 3 doesn't work: I just get different unspecified errors.
Does anyone have an idea where the problem is? Help would be so much appreciated!
(2,064 Views)
Accepted by howhuge
To start read point number 5 on this FAQ. You only have one connection to the arduino.
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,027 Views)
Thank you so much! I changed the code considering this and now it works. Have a nice sunday! 🌞
(1,999 Views)
