Showing results forĀ
Search instead forĀ
Did you mean:Ā
Arduino+LabVIEW
Hi everyone. I have problems communicating with a Teensy ++ 2.0 with Labview 2009, I followed all the steps for communicating with Arduino (this controller can be programmed with arduino) but as soonest I run the firmware it displays the message: "The device is not supported" .... Thanks in advance.
Message 21 of 29
(3,096 Views)
hey all...
i am varun a biginer in labview and arduino. i have an arduino mega2560 board. i want to make a precision temperature controller. for that i am using  pt100 as temperature sensor. to get a resoltuion of 0.001C i have a 20 bit ADC wich i need to interface with arduino. i am using ads1247 24 bit adc for this purpose.can anyone help me in interfacing this adc to arduino mega board with help of labview2012. rest controlling and reading temperature work will b done in labview.
my question is how can i give digital signals to adc from LIFA so that adc starts digitizing and this digitized signal will further processed by labview.i have used this adc befor with 8051 microcontroller so i know the timing instrustion of it.now i am puzzled in how i will handle it in labvie interface for arduino.plz help guys....
waiting for ur responces...
varun
Message 22 of 29
(3,024 Views)
hello such, any consultation with arduino is better than consult in the next group, also find, documentation, examples
https://decibel.ni.com/content/groups/labview-interface-for-arduino
Message 23 of 29
(2,840 Views)
You can see an example for analog reading, make a program in LabVIEW to test and verify the correct operation of our program in the Arduino , we will make the reading of data transmitted by the Arduino from the serial port on the card installed , proceed to read the COM port
https://decibel.ni.com/content/docs/DOC-33278
Message 24 of 29
(2,827 Views)
This article presents a procedure for reading the analog ports of Arduino UNO R3 board , on which a Joystick shield was installed. The analog data are related to the position of command and can be monitored from the front panel of our program , for which we use serial communication.
https://forums.ni.com/t5/LabVIEW-Interface-for-Arduino/Example-Arduino-read-analog-inputs-Joystick-s...
Message 25 of 29
(2,815 Views)
Spammer
Message 26 of 29
(2,811 Views)
i think the problem is your buad rate you will have to change it to 115200 instead of 9600
Message 27 of 29
(2,672 Views)
The last question in this thread was nearly two years ago. I'm not sure why you posted.
Message 28 of 29
(2,661 Views)
sorry i realized the date just after i sent the massege and thanks for your note
Message 29 of 29
(2,633 Views)
