Application Directory VI in labview 7.1
I have a slight issue. I need the location of an application in LV7.1. However Application Directory VI is not available in this version. The closest thing I could find was  “Current VI Path” but it returns the VI name in the path too. For example “K:\LabVIEW\test.vi”. I could just delete the last part but I do not know what the exact name will be. Is there a simple way to get just the containing folder path?
Since I do not know what it will be called + it will be made into an executable I am not sure what the resulting string will be. This is also why I’d like to avoid messing it with string actions.
Thank you in advance!
(3,294 Views)
Never mind I made a small VI that does just that. However I do not know how to delete this post 🙂
(3,273 Views)
You can't delete.
If you want to be helpful for someone in the future.  Attach your VI.
(3,263 Views)
And then mark the post where you include your VI as the solution!
Bill
CLD
(Mid-Level minion.)
(3,248 Views)
Accepted by topic author huntersoa
sorry about the late reply. Also sorry but I could not find the "VI sniplet" option. So here is the section that does the job 🙂
(3,213 Views)
One remark:
Originally I made a version that messes with the resulting string. However that solution does not work well if the vi is compiled. This version works in both dev and application environments.
(3,211 Views)
