Application Builder
I am using LabView 6.1 application builder to make an exe file for my customer where all the correct LV run-time and CVI run-time engines are installed. In my source file, I used labview's out port.vi and in port.vi functions (system.llb which was updated by HWAccess published by NI) while on the destination PC, these two functions are not working. Is it related to the HWAccess and is there any solutions to this problem? Thank you very much.
(2,864 Views)
Hello Michael,
Try installing the VISA runtime on the deployment machine. Make sure you install the same (or higher) version of the VISA runtime engine.
Chetan K
Application Engineer
NI
(2,828 Views)
