how to exit a for loop
i have a "for" loop that contains an operation that produces a true value when the output is a specific number.  i used a flat sequence to perform the operation and a constant of 10 for the "for" loop iteration.  My probem is that when i get to interation three, this produces the boolean to go to true and i want to exit the "for" loop instead of going through the rest of the iterations.  is there a way to exit the loop when this goes true.  for this particular application i need a for loop and can't use a while loop.  thank you
attached is a sample vi that gets the jist of what i am doing.
(3,009 Views)
Use a while loop instead.
Also, the sequence structure in your example is unecessary.  The dataflow will enforce the sequence of operations.
Message Edited by jasonhill on 08-23-2006 01:13 PM
(3,007 Views)
Yes there is no break and continue inside of a for loop unlike many other languages.  This is most likley due to breaking the dataflow model.  2 choices esist
1. while loop with a counter (i>=itteration max) stop ORed with your additional stop condition (stop is true)
2.  Use a for loop but place the code inside of a case structure (less efficient since the loops will continue to spin eventhough there is no code to execute)
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,998 Views)
thank you
(2,985 Views)
