Hi, I'm trying to make a four-point-probe measurement using SMU1, SMU2 (COMMON  and CONSTANT)  and VMU1 and VMU2 (VMUs in diff mode). I have to do this under a magentic field measured as a current by SMU3.
All the examples I found for hp415xa or hp415xb (very similar) did not use the VMUs and I do not know (after trying in many ways)how to add the VMUs to these examples.
Which drivers should I add besides the hp415xa_config-chan-VMUs.vi? (downloaded from ni)
One example is "Getting started" in the hp415xa in the ni web page
and the other example  is "v_sweep_analyser" by wha in the discussion forum.
Can you add the VMUs to any of these examples?
Thank you
Ariadna Kaplan
Message 1 of 1
(2,947 Views)
