Analog Input/Output Palette Missing
Hello!
I have LV 8.6 installed to my PC with XP OS and my card is 6024E. I've notice that the analog input/output palette is not showing up or missing. I've tried the search but no luck. Traditional NI Daq 7.4.4 is currently installed.
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
Message 1 of 10
(5,434 Views)
What does MAX see?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 2 of 10
(5,433 Views)
Here's what I'm looking for as well as the output palette. These shows in the other PC without problem so I don't know what I've missed during my software installation.
______________
KowdTek
LabVIEW 2009
Message 3 of 10
(5,408 Views)
Accepted by topic author KowdTek
Try reinstalling from the Device Driver CD/DVD and make sure you have Traditional DAQ selected.
You did say that you had NI-DAQ 7.4.4 installed.  But if it was done before installing LabVIEW, then LabVIEW won't see it.
Message Edited by Ravens Fan on 02-27-2009 12:17 PM
Message 4 of 10
(5,406 Views)
The drivers was installed after the LV but I'm not aware that Traditional DAQ supposed to be selected during the inatallation.
Thanks for your response.
______________
KowdTek
LabVIEW 2009
Message 5 of 10
(5,400 Views)
I too don't have an Analog Input/Output Palette but I don't have the option to select "Traditional DAQ."  I've looked through the features and cant find it.
Is my version (8.6.1) not have a "Traditional DAQ" option?
Message 6 of 10
(5,249 Views)
Check the 4th post of this thread, that fixed my problem.
Goodluck!
______________
KowdTek
LabVIEW 2009
Message 7 of 10
(5,247 Views)
i am using labview 12.0 on XP OS.even after reinstalling the drivers ,i am not getting the analog input/output palette in the function palette.i am using NI-PCI 6221.
Message 8 of 10
(4,769 Views)
Traditional DAQ isn't shipped with LabVIEW 12.  I'm not even sure if it is even supported, to be honest.  Use DAQmx instead.
Message 9 of 10
(4,758 Views)
yup,fixed up the problem.Its DAQmx...
 thanks a lot
Message 10 of 10
(4,749 Views)
